Jeep has been lifted/w 35's. What to do about gearing and computer now?
Can't speak for the Superchips since I don't have one and don't know if it works with the 2010s yet. However, it does add a few performance options the Procal doesn't have.
The AEV is very simple. They give you a little quick reference sheet that you use to configure dip switches and then you just plug it in with the ignition on and the engine off. Almost as soon as you plug it in the horn beeps twice and your done. You pull the chip out and save it for any future mods.
If the Superchips doesn't work with the 2010s yet you could always get the Procal for now and then reset your vehicle to stock and sell the Procal when the Superchips works for your Jeep.
Once you use the procal once it gets coded with your vin# and can't be used on another Jeep until you reset to factory settings. Else, ya a lot of people would do as you said. Reseting to stock again is a dip switch setting plug it in and pull it out. The Procal does all the essential mods you need, tire size, gears and a few others.
Superchips DOES NOT support the 2010's yet. I went with the Procal first to help with speedo and TPMS but just recently got the Hypertech Max Energy programmer.
Does a lot of what the Superchips does as far as tire/gear size and performance tunes like 87 and 93 octane but it does not have the full feature set of the Superchips.
I drive a Rubicon so the rock crawling tune doesn't interest me (I've heard it makes it way too touchy). I don't tow anything so that doesn't interest me. However, lockers in 4hi and the ability to turn off TPMS are huge to me. So far, I've kept my Procal for the TPMS and have put a request into Hypertech to see about adding 4 Hi locker option.
So you have options for 2010...or even for other years. Hypertech does not seem to get much coverage out here!
The simple answer is NO you don't have to. If you do mostly city driving and it is fairly flat you may get away without new gears. It is not a must change, your Jeep will just have more responsiveness and drive better if you do regear. If I were you I would do the lift and tires first and then drive it for awhile and make a decision then. Just be prepared to spend some time in the slow lane
I see your in Chicago...losts of stop and go driving I suppose. A re-gear with help with making the acceleration better, thus increasing the drivability in your situation.
As far as computer mods, I am happy with my Superchip and the 87 tune. After the re-gear and the tune, I went from 12 mpg to 16 mpg
Procal doesn't do any type of performance tuning so this does not apply. Performance programmers like Hypertech and Superchips have this feature. I believe the benefits are more power and better mpg...but I just installed my Hypertech tune 2 days ago so can't comment of the effectiveness of it yet.
