jeep is all over the road hard to drive
So yesterday I had the tires balanced and rotated on my Jeep each tire has 27 pounds of pressure. The front tires were worn a little more than the back so I have rotated now I Drive the jeep the traction control is coming on every time I lean into a turn can you help me ?
The front sensor voes into the unit bearing assembly up front. On the back the sensors are sticking out of the parking brake assembly on the inside.
Have you rotated the spare in? If the spare is new and the others are worn then that could be setting off your sensors.
It could be a speed sensor. It could also be a unit bearing. But, the most common cause is your steering wheel is not **exactly** centered. A sensor on it makes the Jeep think you're skidding if it disagrees with what other sensors are reporting. Centering steering wheel is a very easy job ...
http://wayalife.com/showthread.php?3...ll=1#post42376
Swapping tires was the ONLY thing that was done to it, correct? No lift? No steering or suspension components added or adjusted?
Rotated tires is all I have done and did a balance it already had a 4 inch lift and was working great before swapping the tries . I'm starting to think the speed sensors are off that is causing this issue
