Jeep Alignment
Ok so I got a lifetime alignment service with my new firestone tires.
Problem is, I noticed on the bill, they set there computer to a Jeep TJ .... when Mine is a JK..... is there a big difference?
Can someone post the specs my jeep should have.... Ive got 265/75/16s and the OME lift on?
I know there is a write up over do it yourself alignment but it would be nice to just be able to give the guys at firestone the specs so they can do it right.
i seen the spec sheet they where aligning my JK to the specs of a 2006 TJ.......... so that should be correct or should I say something next time i take her in for an align
my firestone shop rocks so far, but i have had them on other vehicles i usually get the same dude to do my alignment, he is a jeeper himself so think that helps.
They told me that it wasnt off bad... just tweaked the toe some........
Told me to bring it back after every offroad trip I do and if I add anything to the suspension because theywant to make sure my tires wear good for me
Next time I am there I will tell them that I have a JK not a TJ
I don't want to defend them, but if the software on their Hunter machine is not updated the fastest way to get an alignment going on the rack is to pick a car that the software does have. Even if you have a 06 TJ on the screen, you can adjust the thing anyway you want. All you have to do is ignore the pretty little red and green bars and set it up using any numbers they see fit.
Your JK may be aligned perfectly even if your sheet says TJ. The only one who knows for sure is the tech at Firestone. I'd get the real toe specs and verify the final numbers you were given are in spec.
