JE Reel OE 1310 driveshafts
I received the OE repalcement driveshafts (uses stock flanges). Does anyone have the torque specs for the bolts at both ends (they use the stock hardward).
Thanks
Thanks
Location: Hangin in the sunshine state....staging forum..
from the service manual for the stock shafts the specs are
Front shaft axle flange bolts 81ft lbs
front shaft trans cas flange bolts 15 ft lbs
rear shaft axle flange 15 ft lbs
rear shaft transfer case flange 15 ft lbs
I would think its the same for the JE being they are using stock hardware.
no install instructions
Best thing is to ask the dealer what the factory specs are or order a manual.
Both JE Reel OE replacemet shafts just arrived from UPS today. I took a quick look at the rear and it looks really short. Collapsed it is about 18 inches and fully extended about 24 inches. I measured the stock one to find it is about 24 inches.
With the JE Reel version at 24 inches, you start to see the splines on the shaft itself. Does this sound right to everyone. It came with new hardware but no instructions or part numbers.
Edit - never mind, so much for measuring in the dark. It will fit just fine!
