JE REEL drive shafts
#31
Drive Shafts
This is all helpful other than the non-sense on who is better.
I didn't see an answer to two questions which would help me.
1. Is the u-joint DS relatively straight forward to install?
2. Do these things need to be balanced somehow once installed or are they just bolt in?
tnx
Blue Mesa
tnx
Blue Mesa
#33
tnx
Blue Mesa
tnx
Blue Mesa
2. They are balanced when they are built, and can't be balanced again on the Jeep. The only reason one would need to be re-balanced is if you slightly bent one. Otherwise, they're balanced for life.
#34
The manufacturers may have you measure your Flange to flange distance, but there's not that much of a need for a custom length unless you're using a long-arm system. The stock lengths will work for up to 4" of lift.
#35
Ok,
Thanks for more info.
I'm pulling the trigger on the 1350HD's (while my wife isn't looking!). Figure I'll go large and then not have issues later (I hope).
Any last words of wisdom?
Blue Mesa
Blue Mesa
#36
Thanks for the replys, I figured it was a pretty straight forward bolt in application, I have taken stock shafts off of my yj and put them back on but I haven't replaced them yet so I wasn't sure about any balancing issues. I ordered the 1310 HD shaft to be on the safe side plus 4WD had a 10% off sale so I got it for the same price as the OE replacements.
#37
Hmm...words of wisdom...how about buy me a front shaft too while your wife isn't looking.
#39
