It's new drive shaft time
the rzeppa joint on my front drive shaft is finally starting to spit grease everywhere, so I guess I'm going to be getting a new drive shaft in the next couple of weeks. The part I'm not certain about is: I want to swap my front axle for a d60 in about 2 years, so I would like my new ds to work for both my current setup (d30 w/ 4" lift) and my future setup (d60 w/ 4" lift). Do I need to get a different length ds to fit both properly or would it be best to just buy a 1310 ds and use it till I get my d60? Oh, and I'm looking at either 1330 or 1350 joints if I can reuse this ds after I do my axle swap.
JK-Forum Founder
Thats the info I was looking for... I haven't done any measurements yet, but can you recommend a certain length ds for 4" lift?
JK-Forum Founder
contrary to the great sales pitching some companies have been putting out there suggesting that you need to measure your driveshaft length before ordering one, any off the shelf 1350 JK shaft will work with a 4" lift. they have more than enough travel and you will not have any problems. once you install a 60, your shaft will need to be shorter and you will need to take a measurement at that time so that you can get it to fit properly.
