Issues Towing
Issues Towing
So I have an Unlimited X. Only thing to this point that I have done is swap out the front and rear bumpers, and changed the tires to 33s. With that said I bought a pop up camper for the family for a steal. It weighs in at about 995 lbs per the specs. So after buying it I went out and bought a hitch with and adjustable bar. I installed it (now my orfab rear bumper doesn't fit and will need to be trimmed slightly) and went and picked up the camper. Well after getting out of the neighborhood I came to a stop light. When it turned green, I took a left turn. As I was turning left and accelerating there was a pretty loud pop like noise and after completing the turn the engine seemed to struggle as it shifted to 2nd and third. Thankfully I didn't have to go far but it did happen again when making a right hand turn into my neighborhood.
So now I'm a little concerned with not being able to tow this camper. I have never towed anything with this jeep before. Any suggestions etc? It sounds like perhaps the transmission is slipping but I have no idea. Just concerned that I'm going to cause some damage although this is well within the limits of what I should be able to tow.
What year, gears, and transmission do you have?
Describe the pop noise a little more.
Was it a backfire? Or more like some slack came out of the draw bar?
Are the coupler and ball sizes matched?
My wife later last night then said oh it was probable just the draw bar but I think she was just saying that more as wishful thinking cus as soon as we heard the noise and we both looked at each other and said some thing in the front was going on. I plan on taking it tonight and drive around the neighborhood to see if it happens again and try and isolate it. On a side note I am planning on bringing the jeep to a shop because my tires have been wearing uneven and am getting a wobble right at 50 mph but then after speeding up above that it goes away. Think that is just a tire balancing issues.
This is the draw bar I am using:
Reese Towpower 7-1/2 in. Adjustable Utility Draw Bar-7031300 - The Home Depot
I don't have a ton of experience towing, but if something is popping in the trailer, its crazy how the sound can travel though the drawbar and into the hitch and frame and sound like something is making noise somewhere else. did you add air to the rear tires at least to help offset the added weight from the trailer? that could be adding to the jeep feeling sluggish. HTH
I put some shims in my adjustable draw bar to quiet the thuds.
The 42RLE with 3.73 and larger tires will struggle. It's not a good combination for towing.
I have stock Rubi tires with 4.10 gears, and the 42RLE hates hills when towing, even with O/D off.
Also note I did not have the O/D off. But I was under the impression that would only help once at highway speeds correct?
Are your track bars nice and tight? I've pulled more weight with my 2dr and it's been pretty quiet except the bar moving around. Welding will fix that for me in place of shims that Ron is using.
I would assume so. Never messed with them but I will check them out tonight. I would assume I would be hearing noise if they were lose even during normal driving which isn't the case.
