Issue with Synergy Drag Link hitting Steering Stabilizer
Old 08-24-2014 | 05:23 PM
Enjoytheride's Avatar
Default Issue with Synergy Drag Link hitting Steering Stabilizer
Long story short. . . . I replaced my drag link with a Synergy in the stock position. The DL hits the steering stabilizer when in full left turn position. The lift is a BDS 3" with Track Bar. Not sure if I have something set wrong or need a different setup. Any input would be appreciated.
Old 08-24-2014 | 05:46 PM
Mark Doiron's Avatar
Veteran: Air ForceFJOTM Winner
Would it help to reposition the SS over to the drag link? That's how I set mine up for a similar issue (Currie rods though). SS function is still the same.
Old 08-24-2014 | 05:53 PM
I was just under the jeep considering that option. . . It's a possibility but with the angle it will put a strain on the SS bushings. Not sure if that will be an issue.
Old 08-24-2014 | 06:23 PM
Monte417's Avatar
That adjuster sleeve looks like it's extended quite a bit. Is your steering wheel straight? If that sleeve is shortened I think the bend will clear the ss
Old 08-24-2014 | 06:24 PM
Monte417's Avatar
Also is your axle perfectly centered?
Old 08-24-2014 | 06:38 PM
The adjuster sleeve is right at the recommended max length. I will look at this tomorrow but don't think it will make enough of a difference.
Old 08-25-2014 | 11:22 AM
grim_creation's Avatar
Is that the BDS stabilizer? I had the same issue with mine when i installed the drag link. Swap to something smaller like a bilstein or fox. That'll fix the problem for sure.
Old 08-25-2014 | 12:29 PM
I had two BDS stabilizers that failed on me. . . The shop discontinued using them and gave me a Rancho. Either way... The drag link is hitting the mounting bolt so it really wouldn't matter what stabilizer I use. Synergy thinks it is a compatibility issue and should flip my drag link. I'm going to try a few adjustments and see if I can work it out. I find it hard to believe I'm the only one with the stabilizer in that position using Synergy.
Old 08-25-2014 | 12:52 PM
Can you post a picture of your setup?
Old 08-25-2014 | 03:17 PM
Quick Reply: Issue with Synergy Drag Link hitting Steering Stabilizer
