Installing a Rubi D44 into a Sahara or X
I'll post some pics up and maybe do a write-up once everything goes in, but I've got a couple questions before I get started.
I got a deal on a lightly used D44 with factory locker. Had it regeared to 5.13 while it was still in the shop. Install will be next week.
Installation - should be a straight bolt-in mechanically
Wiring: (I've gotten the pigtails from the donor vehicle - he apparently installed a RJ60 with an ARB air locker, so didn't have any problems cutting the tails off the factory harness for me)
Plunger - two wires - electrically I understand is a straight on/off switch
Locker - two wires - apply 12v to it, and it locks. One black (ground) and one yellow/orange (12v)
Now, I've got all the understanding I need to wire the locker up to a relay, and get it switched on. My knowledge gap is on the daystar switch - how it lights up in particular.
What I want do to is have that light controlled by the plunger switch in the axle, instead of just turning on when I flip the switch on. Actually using the lighted switch as an indicator that the locker is engaged instead of simply that power is being applied to it.
Can I do this? It's a 3 pin switch from Daystar (technically a Carling V1DA 20A 12V). From the 'top-down' there's a pin 7, 2 and 3 (8, 5 and 6 are numbered but have no pins) Appreciate any help from the local geniuses.
Is it as simple as T-ing off the 12v being sent to the locker, and sending it through the plunger and back to one of the terminals on the switch?
8 7
2 5
3 6
edit - from reading another post, the switch looks like I should wire the following:
2 - 12V in
3 - 12V out to the relay (or direct to the locker)
7 - is the ground for lamp, so if I run 12V to the plunger, and run the ground back to pin 7, then the light should come on when the locker is engaged?
8 7
2 5
3 6
2 - 12V in
Originally Posted by TheDirtman
You don't need to use a relay. Just wire up power and ground to the switch, turn it on and its locked. You can use a lighted switch if you want. I just used a covered switch so that it wouldn't get bumped on by accident.
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=166451"/>
Primary question is how to wire the switch so it lights off the plunger.
If the "plunger" you speak of is a dry contact or just a switch, you can just run the ground from the daystar panel switch through the locker switch then to ground. when it locks and closes the switch it will complete the circuit.
