Installing 5.13 gears, need your opinion on gear pattern!
The pattern looks good to me. Be sure to run the gears for a good 15 minutes with no load on them. Then check and see if the differential is hot. If not you should be good to go.
Originally Posted by rza271
How tough was the DIY approach. I've been quoted 2k to have it done professionally. Want to save $$$.
Originally Posted by BrowniesJK
Did you do the imprints under load? It will make a difference.
Hello guys!
Thanks for Your opinions! I really want to be sure about the gear patterns before proceeding. I will add 0.1mm.
I did the imprints under "load". Backlash is set to 0.17mm. Changing gears is very time consuming, lucky me I have lots of spare time!
More opinions?
Best regards
Micke
More opinions?
Best regards
Micke
Hello guys!
More opinions?
Best regards
Micke
More opinions?
Best regards
Micke
