Installing 5.13 gears, need your opinion on gear pattern!
Old 06-30-2012, 06:48 PM
Rich6700's Avatar
The pattern looks good to me. Be sure to run the gears for a good 15 minutes with no load on them. Then check and see if the differential is hot. If not you should be good to go.
Old 06-30-2012, 06:52 PM
BrowniesJK's Avatar
This was mine. Don't know if it helps. It was the same coast and drive side.
Scary DIY isn't it :-)
Old 06-30-2012, 08:29 PM
rza271's Avatar
How tough was the DIY approach. I've been quoted 2k to have it done professionally. Want to save $$$.
Old 06-30-2012, 08:42 PM
No1AP's Avatar
Very time consuming, labor intensive, and A LOT of reading, but nothing someone with a fair amount of wrench time can't do. I did mine and feel very accomplished. Just make sure and measure a lot.
Old 06-30-2012, 09:26 PM
BubbaJK2012's Avatar
Got mine installed
Evo sleeves
Evo guessets
Front and rear gear install on Rubicon
$500 parts
$500 labor
Sleeves and guessets extra!!!
Old 06-30-2012, 11:28 PM
Ten2ndNova's Avatar
Originally Posted by BrowniesJK
Did you do the imprints under load? It will make a difference.
I agree. This makes a huge diffrence on your pattern. I use a prybar and crescent wrench to apply load on the ring gear. Also whats your backlash?
Old 06-30-2012, 11:31 PM
Ten2ndNova's Avatar
Here was mine
Old 07-01-2012, 01:36 AM
Micke's Avatar
Hello guys!
Thanks for Your opinions! I really want to be sure about the gear patterns before proceeding. I will add 0.1mm.
I did the imprints under "load". Backlash is set to 0.17mm. Changing gears is very time consuming, lucky me I have lots of spare time!
More opinions?
Best regards
Micke
Old 07-01-2012, 06:12 AM
BrowniesJK's Avatar
Originally Posted by Micke
Hello guys!
More opinions?
Best regards
Micke
Just make sure you check everything again after you crush the sleeve. If you crush it a little to far it will change everything. Sounds like you have it under control.
Old 07-01-2012, 06:15 AM
bdmckenna's Avatar
Bet your significant other loved you cooking in her oven.
Quick Reply: Installing 5.13 gears, need your opinion on gear pattern!
