Installed XHD front bumber and delta fogs need help...
I need to find out which wire to tap into right inside the drivers side firewall that is a "constant" for my fog and driving light switches... The XHD front and RR winch were fairly easy to install, atleast a lot easier than the rear XHD. FYI... The delta fogs require drilling and self-tappers as they did not mate up with the XHD mounting posts... Also added the Delta head lights with led blinkers inside the headlight, but still need to wire the blinker part. Any suggestions??
