Installed my 4" Rough Country Lift
I am interested in this left kit as well and have been trying to figure out if I need to change out my gear ratio. The research that I have been doing points to the 4.88 ratio. I have a 07 unlimited X 4dr auto. Just want to make sure its back to original stock performance when done. What are your suggestions? Thanks
I've got over 62,000 miles on my 4" RC lift with no problems. No leaking shocks or anything. Other parts have worn out, but not their's. I have wheeled mine quite a bit too. If you look close at my avatar pic, you can see how much flex you're going to get. I do get some minor fender rub, but it's worth it to keep all 4 wheels on the ground. With RC's warranty and great service + JK-Forum discount, pretty hard to beat the value.
my suggestions
....my rear trackbar bracket just broke and i had to have it welded back on. replace the RC bracket with a teraflex, huge difference and it wont leave you stranded like i was. also, extend your rear bump stops....i flexed the rear axle so much that i actually bent my exhaust pipe. just my 2 cents.
