installed jks sway links...
Old 12-18-2013 | 11:11 AM
A'sJK's Avatar
get an adjustable rear track bar...no need for bracket on two inches of lift...jks for 170...just a suggestion...
Old 12-18-2013 | 12:00 PM
ronixwrangler's Avatar
thanks!! i most definantly will!
Old 12-18-2013 | 12:02 PM
aldaman's Avatar
x2, on the mounting and the need for an adj track bar. I have one to center my rear axle. Without it the links would rub my passenger rear tire when loaded (as you can see in the pic).
aldaman
Old 12-18-2013 | 12:57 PM
aldaman
thanks aldaman
Old 12-19-2013 | 05:56 PM
is there anything specail that i need to know before i undo the bottom and turn it around? like can i do this with the jeep just sitting there on the tires without jacking it up??? or will i eff it up without jacking it off the ground?
Old 12-19-2013 | 07:05 PM
jadmt's Avatar
JK-Forum Ambassador
nothing special. no need to jack it up. you may need some up ward pressure or downward pressure on the sway bar nothing else.
Old 12-19-2013 | 07:15 PM
meep97's Avatar
Nope. Just crawl underneath and loosen the two bottom ends of the swaybar links and turn them around and tighten them to spec. You may need to pull down or push up on the swaybar after one of the links is in.
Old 12-19-2013 | 07:20 PM
awesome! thanks guys!!
Old 12-20-2013 | 05:03 PM
Ok fixed it lol
Old 12-20-2013 | 08:31 PM
Pghchamp's Avatar
Looks better
Quick Reply: installed jks sway links...
