Install Party anyone?
Old 06-21-2016 | 06:40 PM
  #31
jordy's Avatar
Originally Posted by InvAdeReKiM
problem solved. got different tires and wheels with different offset than factory.
Perfect!
Old 06-29-2016 | 08:29 PM
  #32
casamtb's Avatar
Looks sweet. Sorry I didn't reply. Have been slammed. Looking the the rear sway bar, they are on right. U may want to flip the lower bolt. Head in bolt out. That's is the way the links are set stock. I really don't think it matter one way or the other, however it look like the threads are in the way of the track bar bracket bolt. At least it looks that way in the pick. It also looks form the other pick and the position of the rear track bar that u got 3+ in the back and may want place correction wedges under the rear coils. They look bowed in the photo. Also make sure you retorque the tack bar bolts after a bit, they will stretch. Again, it looks sweet. Enjoy.
Old 06-29-2016 | 08:38 PM
  #33
casamtb's Avatar
Oh yeah, lose the rear brake drop brackets if you plan to off-road her. I say this because I had installed them because I didn't have the time to do a brake line swap before a trip this year. The longer rear sway bar links snagged the dropped stock line along the rear frame rail and tore it all up. I should have just installed the extended lines with the lift but live and learn.
Quick Reply: Install Party anyone?
