Impact Tools for Lift Install
I am getting prepared to install the 3" OME long travel lift kit that I bought from David at Northridge onto my '08 JK 2-door.
I have read many of the threads on the subject of lift installs, and I believe I have most of the tools. I do have a couple of questions, though.
1. Is a swivel necessary if I use an impact wrench? If so, can someone explain to me the difference between a "universal" and a "swivel universal"? There's quite a big price difference for Craftsman, and I'm not really sure what more I'm really getting with the swivel universal.
2. I have read about situations in which a 2' crescent wrench (or pipe wrench) is necessary. For the installation of adjustable track bars and adjustable upper control arms, would one of these be a good investment?
Thanks for any input.
Jeff
Jeff
as the saying goes use the right tool for the right job, if you don't use a tool right you risk damaging your tools and what your working on... that said a creasan is a good tool to have, but use it right (they tend to round off bolts). as far as impacts go they are designed to remove fasteners not install them, you risk breaking bolts, though i do use a impacts to put install i am care full not to over torque and i make sure the bolt is threaded properly before hand, as far the universals and universal-swivels ill get an answer for you soon.
the universals are cheap so if your only gonna do this once I would get a universal, but if you do this a lot (if your a profesional mechanic) get a universal swivel socket set.
I have a 1/2" universal but didn't use it when I installed my F/T 3" ultimate. I got away with "wobble" extensions. I mean it took some clever (pat on the back) combinations of wobbles and non-wobbles but it worked. I used a cheap 1/2" impact but it's really not necessary...speeds things up some. I got a big ass crescent from Harbor Freight to tighten the jam nuts. About $16 and it really looks cool
Thanks for the Input
Hi noidea,
I agree... the right tool is "almost" always the best approach. The point about the crescent wrench was in regard to something I had read... purchasing wrenches for nuts 1-1/2" and bigger can get expensive quick. And, when you only use that size tool occasionally, I am thinking I'll take my time and be extra careful might be the most prudent choice.
I'll look forward to your answer regarding the difference between a universal and a swivel-universal. (Hopefully I won't need to turn into a professional mechanic with my Jeeping fun, so I'll probably stick to the universals, at least for now.)
Thanks for your help.
Jeff
Jeff
Thanks Mike
Hi Mike,
I think I read a different post of yours that indicated you had an 18" crescent. Any regrets with not going bigger? The 24" isn't too much more expensive at Harbor Freight. Do you prefer the adjustable wrench to the pipe wrench others have suggested for the jam nuts?
(I'm confused about your wobbles reference, too. Are you referring to the sockets with the built-in universals, or am I really out to lunch?)
Thanks again for your input.
Jeff
Jeff
he is refering to drive extension with a tappered squar drive at the end. you get a good amount of play without the frustration of the universals. they tend to be a bit pricey though.
there's the set from snap on, sorry i dont know how to make a clicky
http://buy1.snapon.com/catalog/item....re&dir=catalog
An impact can save a lot of time since most of the bolts that the factory uses need to be wrenched completly loose.
I used a universal and a long and short extension all on 1/2" drive. 21mm-13/16 and 19mm-3/4 gets most of it. 18mm and 16mm gets the rest.
Jeff
Jeff
