im getting 11.5 mpg with 35's and 4 in lift, is that normal?
Old 01-03-2013, 08:46 AM
Shell's Avatar
Always amazes me how ppl get the same or better MPG when they lift, bigger tires and regear.
Old 01-03-2013, 08:52 AM
Brightwhite's Avatar
Originally Posted by bombout800
What are you doing wrong? Do the gears hurt mpg that bad w the higher rpm. Im with 3.73 and 35s if I baby it and stay in eco at almost all times I can get 15.7 avg
Huh? What do you mean what am I doing wrong? I dunno. I just drive. I dont drive like a manic, usually at most 5mph over the speed limit.
Old 01-03-2013, 09:24 AM
mpkelley20's Avatar
To the OP: You have a 2007 JKU X with 4.10 gears, 4" lift and 35" tires with no other mods like HD bumpers/winch/sliders/skids, correct? If so, then your mpg is either messed up due to the leak, a speedo not properly calibrated (both of those previously mentioned) or you have a seriously screwed up engine. My guess is your speedo is not calibrated for the bigger tires so that is most of your issue.
Without continuing the "I get XX mpg" thread here...you can expect anywhere from 12 to 18mpg on average with your setup with everything properly dialed in. Of course, tons of factors can change what you actually get such as tire type and tread, PSI used, driving style, temperatures outside and the type of gas (winter vs summer gas if that truly exists), elevation of driving (including normal hilly terrain...not just elevation of where you live) among other things.
I think the 11 sounds more like someone running a fully loaded down rig on 37's rather than a lightly modified rig on 35's. I bet if you check your speed against a GPS (can use an Iphone/Smartphone app), you will probably find your speedo is off 2 or 3 mph at around 65mph. That will completely throw you mpg off.
If your speedo is perfect and ficing your exhaust leak doesn;t help....then I think you have a bigger issue to deal with...
Old 01-03-2013, 12:09 PM
JK-1's Avatar
is it possible that is your programing in 35's and your tires are acually 34's that you would be making your gas milage look better than it actually is just wondering
Old 01-03-2013, 12:11 PM
skibovr6's Avatar
Man, my 2011 6 speed 35s 373s gets 14mph. Its flat around here and I drive it well but I thought that was bad, LOL!
Old 01-03-2013, 12:14 PM
White-JKU's Avatar
Idk what you're doing but I'm getting 14.2 with 40s and steel wheels with 4.10 gears in my 07
Old 01-03-2013, 12:40 PM
ihodge82's Avatar
Originally Posted by Zpack
I have a 4" lift and 35's and get 16mpg but I'm running 5.13's and flashpaq with an auto
How's your pick up? I have an 07 with 4" lift and 37x13.50. I'm abut to regear to 5:13 in a month. What are your highway speeds in OD?
Old 01-03-2013, 01:44 PM
1slowjeep's Avatar
i have the superchip flashpaq and i used mapquest miles from home to work to know the milage and seen how much i used one way. i could be off by .5 mpg one way or the other. i use the performance 91 oct tune and run 30 psi in the tires. i did notice a drop in mpg when i went from 40psi to 30 but the ride quality sucked ass at 40 psi. i think i need to regear, i am about to do bumper and winch. (its also a hard top). it works the hell out of it to keep 70 mph on the higheway uphill (rather steep hill) without a second gear 5k drop.
Old 01-03-2013, 02:32 PM
WranglerRush's Avatar
I get 16.5-17.5 mostly highway with 285/75R16 with 4.10 and manual
Old 01-04-2013, 07:43 PM
Craneguy's Avatar
I have a 2012 JKUR, with the stock tires (31") and 3.73 gears, AUTO I was getting 17 mpg in the city! Well rural area up hill and down hill. Never had a chance to do hwy estimate. At 2500 miles I changed everything just about, 6" teraflex elite long arm suspention, fox 2.0 reservoir shock, teraflex speed stops, sleeved & gusseted, 38 x 13.5 x 18 toyos, 9.5 warn winch Smittybuilt front & rear bumpers, ATX wheels after market .250. Wall drive lines. So as you see I've added a lot of-weight and still running 3.73 gears and the jeep still had some balls! But I was having transmission issues, "search for gears/shit points" and mileage dropped to 15 mpg in city. So 3.73 not doing for me so I re-geared to 4.88s, opt for the bigger R&P and better mileage I thought? I went to a G2 gears now my mileage is 13-14 mpg in city! Worst ;-( I did the pro cal right off the bat! Double check speed with on board nav and it perfect! Tire pressure is around 35 psi. Are G2 gears crap? I'm a little lost!
1035 RTI RAMP SCORE
ID:	405655   Click image for larger version
ID:	405657   Click image for larger version
Quick Reply: im getting 11.5 mpg with 35's and 4 in lift, is that normal?
