Im confused 2007 jeep wrangler jk 6speed
Old 10-11-2015 | 12:46 PM
Jasoncinpean's Avatar
Default Im confused 2007 jeep wrangler jk 6speed
Clear fluid after I shut the jeep off spewed out of a vent plug looking thing just above the slave cylinder? Anyone know what the heck this is and why? Only ran the jeep for like 15ish minutes although all be honest I kinda stepped on it a few times. Here's a photo Spewed out of that vent plug area, rolled on to slave cylinder and than down to the vent area were tranni is and dropped on the ground plus cat pipe.
Old 10-11-2015 | 12:47 PM
Liquid is clear not collant color
Old 10-11-2015 | 12:57 PM
richlortz's Avatar
Did you have the A/C running
Old 10-11-2015 | 01:36 PM
Biginboca's Avatar
This! The AC drips condensation above the bell housing and it drips down by the slave cylinder. You should taste it to verify, lol
Old 10-11-2015 | 06:05 PM
I smelt it and it smelt like nothing. I can't remember if I had the ac on to be honest though dang it
Old 10-11-2015 | 06:06 PM
I can't remember but the liquid had no smell and was clear color a lot came out tho and I believe it started once I turned the engine off but than again when your in the cab you don't hear it...
Old 10-11-2015 | 10:05 PM
Just drove home this evening another 15-25 minute drive. Ac was off and it did the same thing when I shut it off in the garage just dropping from same vent. Clear liquid smells like nothing
Old 10-12-2015 | 07:02 AM
davids2011jk's Avatar
its just water from your hvac system, even if you didn't run the ac right before you shut it off it can still have some water in there. i wouldn't be worried about it
Old 10-12-2015 | 09:10 AM
Thanks man! Noob question though. Why would it be collecting water like that? It did rain pretty bad not yesterday but the day before and the jeep was out side in it
Old 10-12-2015 | 09:46 AM
the air inlet for your hvac system in on top of the cowl right behind the hood, rain goes right into it, theres a drain for that water that gets in it may be the same drain, either way its a very good possibility thats where your water is coming from. id not we worried about it at all.
Quick Reply: Im confused 2007 jeep wrangler jk 6speed
