If you have installed a TF 2.5 Coil lift please chime in.
#23
Sponsoring Manufacturer
#24
I just installed this lift this week, and I had literally no experience doing anything like this.
From a newb's point of view.. Spring compressors aren't needed if you loosen all the control arms beforehand (which you should), and you watch all the hoses/lines going to each axle. If the jeep is high enough on stands and everything is loose, the springs go in very easy. I did remove the brake line/abs bracket on the front axle down by the lower shock mount to allow it to droop low enough, reinstalled it before bolting back up the lower shock bolt.
A little grease on the bumpstops in the front and a bottle jack made quick work of those..
The track bar bracket which I did install (for now), was off by just a hair. I used a dremel ever so slightly to get the small bolt in, while the big bolts lined up just fine. I'm satisfied with it for now.
Good luck, the lift rides great, the steering on the other hand needs some tweaking, but I expected that.
#25
didn't know you could just skip the bracket....what's the difference between having it and not? i put mine on after alot of frustration from drilling the hole a tiny bit off.
#27
I've had teh TeraFlex 2.5 spring and shock lift since Nov 2009. Installed with 35x12.5 Mickey Thompson MTZ on stock Rubicon wheels with Spidertrax wheel spacers.
The lift is generally good. I would suggest going with a softer shock than the TeraFlex 9550 unless you run at fully loaded capacity with 1500 lbs of cargo. The springs allow significantly more flex, and I do recommend getting a set of brake line hose extensions because with these springs on a Rubicon with swaybar disconnected you can easily kink the stock hose lines.
On the street and gravel trails it handles great and does not wallow at all.
I developed a bit of Death Wobble in January 2011, and got all 4 wheels rebalanced greatly improved it, but not 100%. I am thinking about the Heavy Duty trackbar next.
Admittedly, I drive it like I stole it - so your mileage may vary.
#28
So do you offer a non drill 2.5 spring kit with shocks? I don’t know much about lifts but want to make sure I do it right. I don’t want to drill in my suspension
#29
#30
