If you had to choose....?
between a susp. kit that includes lower arms & no front track-bar [just bracket] ---BDS---
OR
a kit with cam bolts & a track bar...---ZONE--- also cheaper of the two
ideally i know you'd want it all, but the budget is not deep enough right now.
would upgrade at a later date for sure. Just need to know where to ''sacrifice'' function temporarily
sorry if this don't make sense, i've had a sum ''christmas cheer'' tonite
OR
JK-Forum Founder
the link below goes to a post that was made today and the user makes a comment regarding his cam bolts that i think you need to read:
https://www.jk-forum.com/forums/show...13&postcount=5
cam bolts are a cheap solution that i strongly would not recommend using.
now, having said all that, how big of a tire are you wanting to run? do you really need to get a coil lift? being that you are on a budget, you really should consider getting a budget boots like teraflex makes. it's affordable, comes with everything you need, works great and with the addition of a body lift, you can easily run 35's with it.
![Yup](https://www.jk-forum.com/forums/images/smilies/yup.gif)
now, having said all that, how big of a tire are you wanting to run? do you really need to get a coil lift? being that you are on a budget, you really should consider getting a budget boots like teraflex makes. it's affordable, comes with everything you need, works great and with the addition of a body lift, you can easily run 35's with it.![Yup](https://www.jk-forum.com/forums/images/smilies/yup.gif)
seen the post and that's what got me thinkin.
I've got the 35's sitting in the shed waiting.
JK-Forum Founder
