I want a 2.5 BB, but not death wobble...?
Sponsoring Manufacturer
1 Post
Oh, I thought I did mention tf kit (terra flex) just buying it from northridge. I just wanted to verify a firm shock to meet my towing needs. I think my sahara came with beefier shocks and springs from the factory because of the oem tow package.
I am on my iPhone, hard to type
I too went with Rough country coils and shocks. no wobble. have not pulled a trailer with it yet though. I am pleased with the RC and would recommend it to anyone that might listen.
JK-Forum Founder
Oops!
A steering stablizer will not cause a wobble, rather it will mask the real problem. If your friend is masking a real problem by using a HD steering stablizer, he may end up with a serious problem when the loose suspension and/or steering components fail because they damage brackets or bolt holes. He needs to have all his suspension components re-torqued with the full weight of the vehicle on the ground.
I have an 07. No wobbles except for when I both put my alignment out and smashed my steering stablizer on a rock. Removed the steering stablizer and re-aligned--no wobble. Then, I added a Woods relocation bracket and new stablizer.
a steering stabilizer or lack there of WILL NOT cause death wobble. this is a myth that i hear spread all the time and it simply is NOT true. if you have your suspension dialed in, no mounts or bushings are failing and all your bolts are tightend to the appropriate torque setting, you will not have death wobble and you won't even need a steering stabilizer.
is it possible?
My jk is a dd rig. It also tows a small trailer. I get it off road 3 to 4 times per mo. It goes hunting & fishing with me.
I want the slight lift of 2" or 2.5" for slight increased clearance and for looks. Face it, A lifted jk is really cool I am keeping my stock rubi wheels & tires. I don't need bigger tires & wheels.
Should be easy but everyone I talk to, other jeepers, other forums and article continue to tell I ominous "death wobble" warnings.
Does every jk with a bb lift have problems?
I started with the TF 2.5 BB then because of heavy bumper and winch with with the TF 2.5 coils. Everything installed according to directions of course. I have had no problems at all. don't even understand why people have the death wobble
It's also a DD and sees some really good wheeling...
Maybe I'm the 1% that has a problem, but the day I installed my RC 2.5 BB my front end has wobbled coming to a stop more than 75% of the time.
Tire pressure = good
Torqued bolts = good
Steering wheel = re-centered
Problem = UNKNOWN
Problem = UNKNOWN
same here man except mine is the teraflex bb..i have an adjustable trackbar on the way..hope it fixes it
