I need some help...
I keep a check on the welds. I have always been worried about bracket, but so far it is holding up well. I can't believe i missed the pitman being loose.
![Synister](https://www.jk-forum.com/forums/images/smilies/synister.gif)
If your pitman arm is loose, it will cause that clunk. Mine did that here a short while back; only did it when I 1. either was backing out, or 2. was trying to do a tight turn. Not very often, but enough to drive me bonkers. Come to find out, the pitman arm had a little bit of play to it. Tighten it up and see if that helps.
Mine is doing exact same thing interceptor. I swore I had the arm tight when I did the lift last christmas. I drove it to work this morning and the steering stabilizer stayed in place. Hopefully no more problems out of that. I gotta get me a socket big enough to tighten the pitman arm back up. Shouldn't those u bolts hold pretty tight. I tighten hell out of them, but I don't know how it fell the first time. Thanks again guys.
