I need the Schematic of the speed sensor...Can you say Recalibrate??
Old 04-25-2007 | 06:16 PM
Tom07JK's Avatar
Default I need the Schematic of the speed sensor...Can you say Recalibrate??
Anyone have the electrical schematic for the speed sensor? Where is it located? Usually on the rear axle, but I haven't checked. I am willing to be a Guinea Pig for recalibration. Give me the wire colors or pin numbers and the corresponding descriptions and I will let you know my results.
Thanks,
Tom
Old 04-25-2007 | 07:12 PM
IGOFSHN's Avatar
It is called a computer. Not on the axle or the tcase.
Old 04-25-2007 | 07:17 PM
Tom07JK's Avatar
Fshn-
Do you know what you are talking about? There is a speed sensor that sends the vehicle speed to the computer. This is true for almost all new cars. Pinouts please....
Tom
Old 04-25-2007 | 07:37 PM
TEV's Avatar
TEV
Originally Posted by Tom07JK
Fshn-
Tom
im sure there is an actual sensor but I know the recalibration is done through the computer. You say it can be done through the wires??? This is over my head but ill be interested to see what happens. Sorry im no help, good luck.
Old 04-25-2007 | 07:40 PM
RedRockJK's Avatar
You could intercept the signal that goes to the computer, and fool it into thinking it's going a different speed. It's an easy way to recal the speedo if you know where the signal is coming from.
Old 04-25-2007 | 07:41 PM
Tom07JK's Avatar
There are recalibrators that can be placed between the sensor and the computer that alter the sensors signal so that a different speed is displayed. This works on any vehicle and is not specific to the JK. I just need the wire descriptions to know how to hook it up.
Thanks,
Old 04-25-2007 | 08:21 PM
RedRockJK's Avatar
I have the 07 Service Manual and Wiring diagram. I think they may have changed the 07's where they don't use a single speed sensor any more. It looks to me like they might be using a combination of the four wheel speed sensors (which are an intergral part of the ABS and ESP functions) to come up with the reading for the speedometer.
There are input and output speed sensors on the transmission. I suppose it's possible they use the tranny shaft output speed for the signal, and let the computer compensate for what gear you are in and what gear ratios you have.
Old 04-25-2007 | 08:27 PM
Tom07JK's Avatar
Tell me more about the sensors on the tranny. I am sure that the ESP system uses a lot of sensors to decide when to activate, but the speedo must rely on a tranny or t-case sensor. It would be the only place to get a constant reading regardless of turning/4WD etc..
Thanks,
Old 04-25-2007 | 08:32 PM
RedRockJK's Avatar
I'll see if I can take a screenshot of the wiring diagram and pinout on the output speed sensor on the tranny(s).
Old 04-25-2007 | 08:33 PM
Tom07JK's Avatar
Awesome!!
Thanks,
