I need lift help ...please
I wanna run 33 I don't wanna go to crazy I want stock ride if not better. What would u do a leveling kit spacer lift or a coil lift
Man there are a few posts on here about this, but I think you will find most will say if ya can go a few more $'s do the coil lift = better ride, mild off road'ing, etc.
The new sponsor Rusty's had a coil lift for about $320 and 4WP has one about the same, good luck with ya mods.
You already made another post with the same question. 2.5" coil lift for 33's. You already asked about the rusty's just go for it. Great product for the money. You wont regret it
Originally Posted by mpkelley20
For what its worth (and knowing you've already done your homework on various lifts and have spoken to vendors like Rustys), I'm pretty sure you can run 33's without any lift. Guys on here can fit 35's with no lifts if they go to a flat flare. Not sure what stock tires you currently have but my Rubi and saharas come with 32" tires so I don't see why you can't move up 1" without a lift.
Plus, you said you only plan on doing light wheeling. At worst, maybe you need to either look at flat flares or go to a different wheel with your 33's that have different back spacing.
Since you keep saying in all of your threads that you want stock ride or better, this is the only option you have. Once a lift goes on (BB or coil), you introduce the potential for many issues and (depending on your dealer) warranty issues.
I would ask a question of "Can I run 33's with no lift" since its the 33's you seem to want. I'm sure you will get plenty of responses but I think you would be fine with no lift.
Flat fenders are definitely an option but will cost more than an inexpensive lift. You could trim your own fenders if you don't mind cutting the stockers. Also you could pick up some used rubicon springs that will give you a little lift. Just take your time and do lots of research and decide what is best for you, how you will use it, and your budget
A budget boost like the teraflex 2.5 spacer lift with the shock extensions can allow you to run your stock shocks. You will keep your same ride qualities. Same goes for the levelling kit.
