i need to know where this goes! i think its a track bar relocater
You remove the Rear track Bar bolt on the left side of the axle, than that piece bolts in where the track bar bolted into moving the track bar above the axle. rebolt the track bar to that piece. if that makes any sense to you. that will lengthen the track bar for the lift you installed
You will have to drill a hole in the factory trackbar mount to install. The old TF kits came with that style. I have since yanked mine and replaced with the axle mounted reinforcing trackbar bracket.
