I lowerd my jeep
In not sure what you're asking?? If you haven't adjusted the track bar, then adjust it. I'm not sure what I'm supposed to be looking at in the pics either. Pic #1 and #2 just look like they show a 2x4 vs a 4x4 front end. The 3rd pic just looks like you've changed out some components and painted them. I don't see the driveshaft that you're having the issue with. How much did you lower it by? Which kit did you buy and did it advise against excessive weight? Just asking for a little more details.
And I didn't notice until today , I had a issue with my drive shaft hitting the tranny and I couldn't figure out why so the plan was to bring my axle a little more to the driver side to fix it
But I went out to take a after picture and I put the before and after picture next to each other and bam I notice why my shaft is hitting after adding a bunch of weight my jeep has gotten lower and I never fixed the track bar for the height
Before where the track bar is
After now where it sits just with added weight
If the adjustment helped you, great but I just don't see the difference between the before and after The exposed threads where the trackabr is adjusted looks about the same to me in both images
If you look at the before and after pics, you can see how the trackbar is lower on the after photo. As reference, look at the 'dimples' on either side of the diff cover.
I haven't adjusted yet , I was amazed how much it change since the weight and have not noticed a difference with driving it
