I honestly dont know what to do..
Old 01-25-2008 | 01:21 PM
skydyvyr's Avatar
Default Sounds Interesting
I'd like to hear how this project goes...
I am curious tho-- will you be grabbing the computer and electronics from the wrecked Rubi as well, or are you going to try and get your computer reflashed?
The 2wd and 4wd run different software on the ECU -- At a minimum, you'll probably have difficulty getting the lockers and e-disco working without the correct software. On the more technical end, the ESP might not like the conversion from 2-4wd either.
Finally, if you are going to use the ECU out of the Rubi, you may need to get some of the other computer/controllers as the ECU broadcasts Make/Model/VIN data on startup that if it doesn't match could prevent other items from working correctly. Burnsville Offroad might have some knowledge here as they replace the 3.8l with a HEMI something that definitely requires a change in programming.
Sometimes I really miss the old days where you could build a FrankenJeep without having to worry about computers.
--Sky
Old 01-26-2008 | 09:45 AM
adgraybda's Avatar
As far as tires go, with a 2.5 inch lift, you can fit either 33"s or 35"s
Here, this is the 2.5 in lift show off thread. There are alot of set ups with
either 33"s or 35"s so u can see what u like best
https://www.jk-forum.com/forums/jk-show-tell-33/tf-2-5-hardcore-offroad-pics-20240/
Old 01-26-2008 | 09:57 AM
crazyhorse02's Avatar
--Sky
i feel ya..i obviously was just starting to consider all of the computer stuff right when i read your post..im knew to jeeps as a whole(been a mustang guy for awhile, still am ) so i dont know which companies to look for as far as reflashing ecu's or being able to just chip it and solve these problems or actually get a whole new comp. so with that being said i called around and most people are stumped..the one suggestion i did get was to try and call jeep an order a new ecu for my vin and just have it flashed with 4wd and etc...but im pretty sure that will cost atleast my left nut..so idk what to do
