I got an alignment done, now I need more imput.
I really appreciate all the imput on this subject. I just want to make sure I'm understanding this right. I should get the adjustable control arms, and have them set to 6-7 degrees of castor.
I don't see any other way to acheive that kinda caster, so, yes, I believe that's gonna be the only option. You may need to compromise because of driveshaft vibration.Remember, as you adjust the control arms for more caster, you are rotating the entire axle housing. This changes the working angle of the driveshaft and may result in a vibration. It may not....but you won't know until you try. At any rate, you should be able to reach a happy median where you get good handling and no vibration.
