I get a click, click, click nosie when I start moving....
About two days ago I noticed that when I start moving I hear a click, click, click noise comming from the front end. It gets a little bit louder and faster as I pick up speed but then get drowned out by the hum of my tires. No there is no zip tie on the DS.....
I was planning on re-greaseing/tightening everything this weekend anyway but I have no idea where to start with this sound... Anyone ever have this problem before?
JK Specs:
2008 2dr rubicon
RE 4in list
35 in procomp tires
Coast front/rear driveshift (about 2,000 miles since I installed the front DS)
re-geared 5.13's by ORE (about 15,000 miles since install and about 5,000 miles since last fluid change)
21,000 miles
JK Specs:
2008 2dr rubicon
RE 4in list
35 in procomp tires
21,000 miles
something outside but not high pitched......sorta like having a ziptie on the driveshaft just not as fast or consistent....and it does not happen while I'm in reverse. I'm almost thinking its a bad ujoint where the axle meets the tire area.
JK-Forum Founder
hmmm, well, checking the u-joints is definitely a good place to start but typically, when they start to go bad, you only really hear them when turning and moving at the same time and even then, it doesn't really make a ticking sound. still, i would give them and the u-joints on your drive shaft a look. if they all check out, i might recommend that you open of your diff and check the teeth of your ring gear. hopefully it's not that but, what you have described sounds like you could have chipped teeth.
Make sure you don't have a rock stuck in your tire. My parents have a gravel drive and my 37" bfg's pick rocks up like champs and occasionally one won't fall out. luckily I don't have to go there to often unless it's to pickup my son. Could even be a screw or nail sticking out.
So great news!!!! Not really....I took out the drainplug on my PS diff cover and let a few drops of fluid come out into my hand. It was very shiny and silver colored....This is not looking good.
I'm here at work so I can't pull off the entire cover without making a huge mess
I had a center cap on my old TJ's stock rims come loose, was held in place by a little set screw and as I drove, it clicked, sped up, etc... Not sure if you've got any sort of rim design that might cause the noise.
