I cant take it anymore!!!
alright everyone. im about to pull the hair out of my head. im pretty sure my tires are cupped. i had my jeep aligned and tires were rotated. im running the toyo open country mud terrains in 35/12.50/r18. im gonna end up buying new tires because the vibration is driving me up a wall. should i stick with the same tires or go for something else? ideas? suggestions? solutions?
Forum Tech Advisor
If you fixed your alignment, your shocks are good and your ball joints are good, swapping to new tires should fix your specific problem.
Cupped tires cause vibrations. You can sell them to someone with a trail rig, and they will be fine, but not for a daily driver.
Next time, don't buy used if they are cupped or feathered. Rotate the tires every other oil change. Keep your rig aligned, and replace worn parts immediately before they cause other problems.
Before junking the tires, I would have them "Road Force" balanced. The tires could also be "out of round". I had a set of BFG AT's that drove me nuts as well.
Good luck with them ....
May be more going on than alignment. Remember, alignments are done when the vehicle is static. When you drive, it's dynamic. Which will then expose loose ball joints, worn mounting bolts (track bar, control arms, etc.). When the vehicle sits nice and calm, simply wrenching it to get the alignment done won't expose loose or worn fittings. You need to get the weight off of it. Lift it, support the frame, remove all the wheels, grab and wiggle each hub, remove bolts, check for wear, looseness, etc. It's a chore, but only takes less than a couple hours to check it over. It's worth doing at least once a year. If you are off road, do it more often. Just remember, these things are built for the masses for the most part. Going off road taxes equipment. That is why there is so much of a market on upgrades.
Before you buy tires, invest a few hours, check it over, or take it to a good 4x4 shop to check it over. Don't go to a general garage. The 4x4 shops charge about the same as a regular garage. You might as well have experience and knowledge on your side for the same $.
when i rotated them the vibration went away. so i guess something is causing them to cup or the tires are defective. i did buy them used a couple years ago off craigslist.
