i am sorry but i need to know...
Old 01-18-2013 | 02:03 PM
brady1929's Avatar
Default i am sorry but i need to know...
can i use the stock 17x7.5 rims with lt31570r 17 tires? someone just told me the rim is too narrow for the tire. is this true?
Old 01-18-2013 | 02:16 PM
Vin's Avatar
Vin
You can use the OE wheel with that sized tire. If you search "Overlander" you'll find a Jeep prototype vehicle that uses the steel winter/offroad wheels that are the same dimension on their rig. You'll probably need spacers because of the offset of the OE wheel.
Old 01-18-2013 | 02:18 PM
Dbmoorejr's Avatar
They are a bit narrow. Need a bit wider to get good wear out of tires and they may be a bit unstable in corners. I had mine on 9 inch wheels neighbor on 10 inch and he got a better ride on same vehicle. Good luck.
Old 01-18-2013 | 02:30 PM
planman's Avatar
Forum Tech Advisor
It is doable, but you have to run the tires at a lower psi to get flat treadwear.
Some tire shops won't do the install.
Old 01-18-2013 | 02:33 PM
JK-Ford's Avatar
It's usually relatively safe to go 1-Up on the width recommendation by the tire manufacturer. Any larger and you risk breaking the bead when cornering. And improper tread wear.
