I was about to get Rockstars but....
So I was looking into getting some EVO rockstars for the added ground clearance and skid plate factor. Plus I was hoping to get some "additional" travel out of the rear. I read around here somewhere that you should measure first, so I did. For reference, I'm running a TF 3" kit with springs, shocks, arms, bumpstops, etc. w/35s
Results:
-Distance until rear shock bottoms out: 8.25"
-Distance until rear bump stops bottom out: 8" (measured to the hard bump stop not the squishy part)
So this means that when my rear tire is stuffed (bump stops hitting), I have just .25" travel left in the shock. So this means that if I were to put rockstars on, which raises the shock 1.5", I would bottom out on my shock first....which is bad.
So here are the options I see so far:
Option 1- Guess I don't get rockstars, just buy some rear control arm skids and call it a day.
Option 2-get 1.5" longer bump stops and rockstars. This seems like a moot point. Correct me if I'm wrong, this route would gain me ZERO additional travel in the rear, all it would do is give me less stuff but more droop. Doesn't really seem worth it?
Options 3-get different shocks and rockstars. This seems like a whole lotta extra cash for miminal payback. My TF shocks are working very nice!
I'm leaning towards option 1 as it is the least expensive and my stock LCA mounts are still in good condition.
I guess I don't get rockstars but I guess that means TF designed their kit well and I'm getting the most travel possible for the given setup.
Is any of my reasoning off? Am I missing something? Are there any other options I'm not seeing?
Results:
Yes, I have the exact same situation. After getting the Rockstars, I was getting a clunk when
the top of the shock shaft was hitting the shock housing. I added 2" longer bumpstops, but
not really happy since, I too, realize there is now less flex. Have the TF long 12" shocks and
feel there is a better solution. Thinking of mounting the top of the shock bracket above
the frame mount to gain an inch or so. Or getting the TF 1 1/2" cone spacer to get more
shock stretch, or get shorter shocks, but like TF ones. Or get 4" rear springs. ??
I was looking into the evo rockstars till I read this. I REALLY dont want to buy new shocks or add longer bumpstops. I guess the Kilby lower shock mount skids would work.
Sponsoring Vendor
Results:
Results:
Unless you were looking for the added 1.5" of ground clearance above the low hanging rear control arm/shock bracket. Is so, your option 3 is the correct course of action for your application.
Our Rear Lower Control Arm Skids are a great application for your current setup. They give protection to your control arms and shocks aswell as gussets the bracket to help prevent failure. These work will all shock/lift applications.
Mel
