Hummer beadlocks or walker evans beadlocks
#21
500 a wheel is as expensive or more expensive than any beadlock on the market. My Racelines were less than that, and they were pretty expensive. Also, I'm not sure why you'd run full beadlocks with the 5x5 bolt pattern. If you were truly planning to use them, I assume you'd envision a manual hub conversion in the future (manual hubs allow you to manage a broken shaft and still get home, among other benefits). That conversion would require a 5x5.5 bolt pattern at a minimum.
#24
I run a beefed up front 44 with Walkers and 37" MTRs in 5x5 bolt pattern. I have run some pretty difficult trails at 10 psi and def enjoy the benefit of beadlocks.
Would a manual hub conversion be nice? Sure but by the same logic I might as well have thrown 1 tons under there and run 8 lugs...
#25
Sent from my SCH-I545 using Tapatalk 4 Beta
#27
You can get pit bull rockers in a variety or sizes as well as interco tires like tsl and boggers both run in a variety or sizes. I think off road you would be very happy with a set of pitbull rockers or super swampers depending on what kinda terrain you're wheeling in.
