how tall are ome light springs on 2 door
There is a bunch on here . There really is not three coils for the 2 door ./
The choices are
Front
OME 615 - Stock / Light load spring 0-90 Pounds
OME 616 - Heavy Load 90-180 pounds
Rear
OME 617 Meduim Load
OME 618 Heavy load 150 pounds
The choices are
Front
Rear
OME 617 Meduim Load
thanks david. Is there much height difference between them? Is the Heavy load significantly stiffer? Thanks man.
Yes there is a lot of differance. You see alot of people posting on here that the OME kit will give you 3" of lift which really is not true.
It will give you about 3" of lift with the HD springs !
The standard springs will give you about 2"
The HD springs dont ride rough in my opinion.
I just did a 4 door with the standard springs and it has a AEV front Bumper and 9.5ti winch and it netted 1.75 of lift.
David
David
I'm saw about 2" in the front (w/ 80lbs Mopar Off Road bumper) and around 2.5" in the back.
I'm really happy.
Just a little rake... I may consider 1" spacers in the front sometime down the road.
I'm really happy.
