How to soften a rough ride?
#21
The very best upgrade to my jeep has been Rancho RS9000xl shocks. They have 9 position clicker to adjust your ride. Most shocks are 1 way only soft or hard that's it. It only takes a minute to adjust them. And right now if you buy 4 of them there is a rebate of 100% for one of them.
#22
#23
Well I have same symptoms as OP except my shocks are new. Only 55K on the jeep, I feel like when I hit a crack or raised section of road it's like I'm hitting a parking curb. I do have toyo m/Ts but there is no way a tire can be that stiff. And when I have anyone in the jeep with me, my rear bump stops bottom out. Feels like Im going to bruise my tail bone lol
#24
I had the same symptoms after installing my lift. I went back and loosened my control arms front and rear, then jumped up and down on the bumpers. I tightened everything back up and it was night and day difference. When I installed the lift I didn't loosen the control arms and I think the control arm bushing where in a bind.
#25
#26
Do E rated tyres really make that much of a difference? I changed coils, shocks and tyres all at the same time 6 months ago and am now trying to solve my harsh ride. I have since added AEV drop brackets and Bilstein shocks which improved the ride, but still harsh. Will dropping back to a D rated with 2 ply sidewall or even c rated tyre make a noticeable difference. I cannot do much with the coils as I have a CRD, so need a firmer coil to take the additional weight.
#27
#28
E Load rated tyres do make a difference, a very noticeable difference. So i swapped my E Load rated MT MTZ 265/70/17 back to my stock tyres just to see the difference. It was like night and day. I then started doing some research, speaking to various tyre places, people etc. i found the tyre vendors and shops were mostly useless, in one sentence they would not recommend a E Load tyre for a light JK, in the next they would quote you one of their tyres that is E rated, and advise you to lower the PSI, because in 265, all tyres are E Load rated.
So i went around to various tyre shops to have a look and feel of different tyres, bounce them, sit on them etc. the Duratracs were definitely one of the softer more elastic tyres, so i took the plunge and purchased a set of 285/70/17, and once again, the difference is night and day compared to the MT MTZ. (MT are known to have a stiff carcus though)
So i once again have a nice riding JK. I cannot believe that a set of tyres could make that much of a difference.
#29
X2 on this one. You can adjust the shock for any type of driving or terrain, plus with their by 4 for the price of 3 shocktober offer, you can't go wrong! I also added a set of metalcloak's dual-rate 2.5" springs (netted >3"s of lift); combined they make for a very nice ride. Now to flip my drag link and adjust my castor...
At what setting are you running the Rancho's shocks in the city and off road
Thanks.
#30
The way the shocks were mounted on that jeep... is that the correct way? Or does it matter if they are flipped. I've never seen them mounted upside down before
