How to replace the inner axle seal on your Dana 44 JK axle
If you decide to sell it and end up needing one, just let me know and I'll ship mine down. I've got 2 jeeps that use the tool here at home and I still maintain my brother's TJ Rubi that could also use the tool. I took it across town last month to help a guy put seals in.
That member hasn't been active in the last 6.5 years, so don't expect a response. It's just simple all thread, bolts and washers there you should be able to piece together at your local hardware store. You really need to have a seal on hand so that you can pick a big washer that is going to fit the seal perfectly and that is what will actually be pressing it in place. I've always used an actual press every time I've had to change seals. It's been a worthwhile tool to have on hand and when I'm tired of looking at it I'll be able to sell it for about what I paid for it, which was around $100-$120 if I recall (years ago).
It's been years since I replaced my seals, but if I remember correctly, we used a short piece of two inch steel pipe, deburring one end to remove anything that might damage the new seal. My friend welded a small piece of flat plate onto the opposite end of the pipe. I held that against the new seal in the differential, then he took a long, one inch pipe, inserted it through the axle tube all the way into the diff housing, then rapped on it a few times with a hammer while I held the other end against the plate. Reversed everything to do the other seal. Two person job, but got it done. I'm a big fan of proper tools, though, so if anyone knows a good place to buy the actual press, let me know. :-)
https://www.yukongear.com/productdet...px?ProdID=5403
I had that Yukon press and the only reason I sold it was cuz I kept seeing $100 sitting on my shelf unused for a good while. It wasn't long after I sold that one that I had another leaky seal. I was actually fortunate to snag the Mopar press off the boards around that time and have had it since. I keep thinking that I or one of my friends might need it at some point again.
Mark Doiron (10-08-2020)
Here we go, Mopar part numbers from the tool in my box. Somehow I also ended up with two sets of the outer pieces.
The outer pieces can be flipped at accommodate the new and old style seals.
Got this added to my wish list for next time I place an Amazon order ...
https://www.amazon.com/gp/product/B0...k_ql_qh_dp_hza
