How to replace front shocks, or at least right side front??
Old 02-15-2014 | 07:13 PM
twotonevert's Avatar
Default How to replace front shocks, or at least right side front??
I searched and did not find my specific answer. I had to replace my front shocks and I did the left side first as it was blown out. Move to the right side and it looks like I have to remove the battery tray?? Is this right? Any tips on how to remove the nut and bushing on the top right side shock? Thank you guys!
Old 02-15-2014 | 07:18 PM
NCRUBI2012's Avatar
What year? 2012 and up your need to trim plastic to get to it.
boopiejones's Avatar
the piece blocking the upper nut is just plastic. if you cut the plastic you should be able to get in there.
Old 02-15-2014 | 07:31 PM
Thanks guys, just wanted to be sure before I did that.
Old 02-15-2014 | 08:10 PM
170-3tree's Avatar
Huh.. I don't remember doing anything of the sort on my 13
Old 02-15-2014 | 08:12 PM
Jeepstin12's Avatar
thats not true. Did mine without cutting. Angled box end ratchet wrench.
Old 02-15-2014 | 08:16 PM
LordV8R's Avatar
same here, just did my lift and I used a ratcheting box end wrench. No cutting required.
Sent from somewhere I really shouldn't be!
Old 02-15-2014 | 09:26 PM
kjeeper10's Avatar
Vet Army
2012 I worked on there was 0 room ?
Old 02-15-2014 | 10:13 PM
Jeepstin12's Avatar
i didn't say it was easy.
Old 02-16-2014 | 12:19 AM
SpicedCrusher's Avatar
You shouldn't have to cut anything to change out the shock. Of course if you want it done as fast as possible you can cut, but it is definitely not necessary...
Quick Reply: How to replace front shocks, or at least right side front??
