How much will 5.13's set me back?
Old 04-04-2011 | 10:42 AM
kellon16's Avatar
Default How much will 5.13's set me back?
I have 4.56 right now. I had the 4.56 installed as a surprise gift when I had 33's. Now I have upgraded to 35's and need to gear to 5.13's. I'm not to sure if they changed the axles when they installed the gears. So if I already have 4.56, what else would I have to get besides the gears and pinions? Sorry Probably a really dumb question but I'm almost clueless about all this stuff.
Old 04-04-2011 | 01:21 PM
jeepmedic's Avatar
Complete overhaul kit about $550 for the front and rear total. Labor...depends on where you live. I paid about $1500 for labor on mine, but that included axle seals and some other misc other stuff.
I have seen anywhere from $999 - 2500 for the whole deal.
Old 04-04-2011 | 01:46 PM
Northridge4x4's Avatar
Sponsoring Vendor
Yep we have front and rear gears and front and rear overhual kits for 550 shipped!
David
Old 04-04-2011 | 02:17 PM
Anaya's Avatar
Should be around 1300.00 cheap side 1800.00 high side most places around Alabama
Old 04-04-2011 | 02:55 PM
STL-RUBI's Avatar
Had mine done in the STL area for ~$1300 including the gears and ARB diff covers. Didn't need the full overhaul kits tho as my rig only had 450mi on it when it was re-geared.
Old 04-05-2011 | 03:14 PM
Gooby's Avatar
i bought my gears for $550 from northridge and had them installed at a local shop for $600 labor.
Old 04-05-2011 | 05:12 PM
anadlas's Avatar
how high should milage be to warrant the overhaul kit? my 09 only has 13K on it?
Old 04-05-2011 | 05:17 PM
nthinuf's Avatar
With use/mileage, the bearings will get worn. But you also have to consider that the installer has to remove them, and replace them, possibly several times. What are the odds that they won't be damaged when removed, or replaced, or removed, or replaced? Go with the overhaul kit...
Old 04-05-2011 | 06:57 PM
nukeman's Avatar
Good advice, and axle seals.
