How Much Weight Before Having To Level (Pic Attached)?
So, I just got done swapping off the OEM bumper and adding the Hyline unit. It's probably a good 90 pounds. I was really surprised when removing the OEM bumper that it wasn't much of a bumper at all moreso that a thin piece of metal covered with plastic. The new Hyline is a big boy.
So, how much weight can I add to the front before having to level it? I can feel the added weight, but am not sure yet if I need to have it leveled. You can get a feel for the height below. My garage is pretty level.
Well JKs really need to be leveled straight out of the factory with their light bumpers. If you add a heavy front, then yes you definatly need to level it. Or you could just add a rear bumper, tire carrier and heavy 35" tire.... it should balance out.
Max out the payload capacity and see how it sits. I'd rather have the rake when empty than have the ass sagging with the front wheel plowing when I have it loaded up.
