How much diff fluid for Riddlers?
I've looked around and searched but havent found an exact answer. I have a dana 44 rear and dana 30 front riddler covers that I'm going to be painting today and hopefully install within the next few days. Can someone please inform me as to what the correct ammount of fluid to put in each diff? Also i plan to use Royal Purple synthetic and was wondering what weight of oil to use.
Thanks for all the help,
Chuck
Chuck
WayofLife's dif fluid change write-up
Here's a good place to start. The Riddler has higher fill hole, but that doesn't mean you need to put more oil in! People on here have said overfilling causes oil to come out the breathers and I believe them.
As posted by Eracer76
CAPACITIES
Engine, with filter..........6.0 quarts
Cooling System, Initial Fill..........13.0 quarts
AMSOIL Antifreeze and Engine Coolant
Automatic Transmission, Initial Fill..........4.0 quarts[1]
Automatic Transmission, Total Fill
4 speed 42RLE..........8.8 quarts
Manual Transmission, NSG370..........3.2 pints
Differential, with 186 FBI Front..........2.1 pints
Differential, with 216 FBI Front..........2.7 pints
Differential, with 198 RBI Rear..........3.9 pints
Differential, with 226 RBI Rear..........4.7 pints
Transfer Case,NV241..........4.2 pints
If you have aftermarket diff covers with a higher fill hole to accommodate a rotated axle, and you fill it to the top of the hole, it will spew diff oil out the vent tube once you get it warmed up driving down the road
CAPACITIES
1 Post
UHM no not the same
Riddler dif cover has a different shape there by displacing the fluid differently actually make the stock fluid level low it take 1.75 quarts
thats 4 pints for the front
don't know for the rear as i don't have that cover
