How many miles with RIPP supercharger?
I currently have an 07 unlimited. I was looking at trading my current JK in for a new 2010/2011 and I am giving serious thought to installing a RIPP Supercharger on the new one. For the most part I'm pleased with the performance of the 3.8, but I would like a little more kick when taking out of town trips, for passing and hills. My question is: How many less miles can I expect from the motor with a supercharger installed? I've already done gears, intake, exhaust, and chip. I've heard (and we all know what that means) that I'd be lucky to get 50K miles from the motor with a super on it. Thanks
I installed the RIPP on my 2008 JKU with around 37,000 miles and only have about 4,000 miles on it since - I love it! I feel that doing the RIPP instead of going for a Hemi conversion was the best damn thing I could have done to my baby and given a second chance would do it again! If I blow my engine at some point, I'll probably get another 3.8l and put the RIPP on that one too
3,000 on mine
I only have 3,000 on mine. It makes a world of difference. I took a 2.5 hour trip two weekends ago. I had a couple of a-holes who when you pass them decide they don't want you to pass or they were going slower than they thought, but do they pass you no they ride next to you on just off one of the corners. I got ticked and pushed the pedal. Next thing I know I went from 75 to 100 (actually over because that is the max on the speedo) and it was cruising.
With the new program the surge issue with cruise is much better.
There is a thread somewhere with mileage and know the test vehicle RIPP is using as over 60,000 on it, I believe.
I expect that if you drive the same way (which is hard to do with all that extra WHP ), maintain your engine properly and ensure the tune doesn't cause detonation, your engine will last just as long as stock. Because the supercharged engine is running more efficiently than a naturally aspirated engine, it may even last longer and should get better MPG. I have heard though that the supercharger itself may only last 100k miles before it needs to be replaced.
We just installed a Ripp kit on my kids 2011 JK, and it pulls slightly harder on the top end than my 5.7 Hemi JK. I would have never believed it! The beauty is that with the V6, the driving dynamics havn't changed. it's unreal what that extra 400 lbs does to the ride and handling of a JK.
right now
I am get 17 and before 20. Before the latest program I was getting back to the 20. I think the computer has to relearn again. I have a trip to FL coming up next month. 7+ hours that will be the real test.
Thanks for the responses. I would like the next JK to be my last for at least a few years, and for myself reliability is a larger concern then performance. Is everyone running the latest Diablo Programming? I'm not to informed on the topic, but from what I understand there was an initial programmer that was being used that was the cause of some headaches. Thanks
We know factually our tune is cleaner than the stock mapping, this is most evident in the trans shift point and throttle feel. Most of you will agree from a drivers perspective there was a huge disconnect between what you wanted the JK to do and what it would do - Many of you would step on the accelerator and it simply would not respond... but once you installed our system the throttle and shift point seemed immediately improved.... For example, during part throttle acceleration most of you are not spooling boost - but you know they JK is faster - that's because we tuned into the extra 200-400cfm the blower is delivering... and when you transition to boost we shape our tune around it... making the whole thing feel and perform like a larger engine.
I agree...there is no reason why the 3.8 won't live a normal lifespan with a S/C installed.
RIPPTECH
