How Long are your Rock Krawler Links?
Hey guys I am currently running a Teraflex 2.5 Coil lift with a 1" TF spacer on top.
I ordered some 3-4" Rock Krawler front sway bar discos and I received these. Do the lengths look right? The main middle bar is 8" long, and as you can see in the picture I can not shorten them up anymore. My sway bar will be angled upwards too much if I install the ones I have. I bought them through the 4wd.com rep here on the forum but they were drop shipped from Rock Krawler directly.
![](http://img.tapatalk.com/18fc41f0-5883-53db.jpg)
![](http://img.tapatalk.com/18fc41f0-588f-b5cd.jpg)
![](http://img.tapatalk.com/18fc41f0-589d-09e5.jpg)
![](http://img.tapatalk.com/18fc41f0-58a5-81b1.jpg)
JK-Forum Founder
your sway bar will sit up high but, it's really not a problem. in fact, depending on how much droop you have, it's recommend that you install longer links to help prevent you from over extending them and bending them on the tie rod. i would install these as is.
I was thinking about that but if I am using them as quick discos, no rubicon here, shouldn't my sway bar be parallel to the ground or no? Thanks for the help
I went ahead and installed them and they look fine. I also had some help from my 14 month old little girl. She wanted to be on daddy's lap the whole time ![Smile](https://www.jk-forum.com/forums/images/smilies/smile.png)
![](http://img.tapatalk.com/44e3948d-ba95-7cc7.jpg)
![](http://img.tapatalk.com/44e3948d-ba9f-97ad.jpg)
