How to find out what gear ratio I have?
Old 04-06-2011 | 04:04 PM
goirish's Avatar
Default How to find out what gear ratio I have?
Im sure its been posted on here but cannot find it. I bought my 2007 unlimited 4dr with a 2.5 lift and 35 tires but I have no idea what gear ratio I have. Is there anyway to find out by vin or codes on dana's.
Old 04-06-2011 | 04:11 PM
Hook-Em's Avatar
Jack up rear end. Put Jeep in neutral. Turn one of the rear wheels while looking at the drive shaft. Count the number of turns for the drive shaft for every turn of rear wheel.
If DS turns slightly over 3 turns, then you have 3.21
If DS turns nearly 4 turns, then you have 3.73
If DS turns slightly more than 4 turns, then you have 4.10
Old 04-06-2011 | 04:17 PM
goirish's Avatar
thank you for the info
Old 04-06-2011 | 04:25 PM
nthinuf's Avatar
Plug in your VIN
hxxp://www.compnine.com/vid.php
Old 04-06-2011 | 07:02 PM
TX2PR2SC's Avatar
Originally Posted by nthinuf
Plug in your VIN
fantastic!
Old 04-06-2011 | 07:15 PM
jeepmedic's Avatar
If you have the factory tow package and a D44 rear, then you prob have 4.10s.
You can also give your VIN to the dealer and ask for a build sheet. This will tell you every part that is on your jeep !
Old 04-06-2011 | 10:01 PM
Rexacon's Avatar
I almost positive on this. Any 07 JK has 4:10 gearing. All my friends that have 07 JK all have 4:10s and one is a X and the other one is a Sahara and both have 4:10 gears.
Old 04-07-2011 | 02:49 PM
Raz70's Avatar
In 07 jeep Jk came with 3:21 gears the only option was a towing option that gave u 4:10.
Old 04-07-2011 | 02:50 PM
Mark Doiron's Avatar
Veteran: Air ForceFJOTM Winner
You could also add the 4.10 gears as a factory option (even without the tow pkg), and the 4.10s came with the autos (and Rubi's, of course).
Old 04-07-2011 | 02:52 PM
Pat Vigeant's Avatar
Default gearing
Another way to check, if you look on the internet you can find charts that will show your RPM vs. Speed at 1:1 (auto in drive OD off)
Pat
