How do you tell the type of lift
I'd pull it apart and check the pucks for any signs of wear that may potentially cause a failure (unlikely but ya never know). Also, get longer sway bar links and I'd also entertain the idea of doing quick disconnects (Teraflex, JKS, home brew) as long as it is apart. But most importantly, GET IT DONE FAST! It doesn't appear to sweet as it is presently.
since all you have is a BB, id do another BB. check out the Teraflex 2.5" Budget Boost. Northridge4x4.com has a good sale right now (coupon "Teraflex"). it will address all of the items i see wrong in your pics and theres no need to break the bank.
That's all good advice...And it is a little unsafe to drive. But it's probably been that way for so long( and not been flexed ) its warped the pucks.. Should be addressed asap. But as far as what lift you have, it looks like all stock but a budget boost pucks. The springs and even the shocks look to be stock.
get the BB or a small coil lift or coil leveling kit. you can find used rubicon coils for cheap around here for sale. i actually have some, if you end up needing to replace the coils.
the coils on there visually look ok. none are touching, which is good. what size tires are you running? you may be able to remove the BB on there and run it stock for a while.
Thanks to everyone on the red flag concerning this setup.
A 2 1/2 " lift kits about 500 bucks depending on what you go with, and you would be all new then. + your guys labor, unless you can wrench? There are some good write ups on here, that walk your thru it . Look thru them before you pay someone to do something you can.
After looking into this BB issue, I decided to go with the TF 2.5 coil lift with shocks. After looking at the great writeups on JK Project I decided to do the lift myself. I have the tools and the knowledge and the
David at Northridge 4x4 was very helpful. With 66k miles on the original shocks and the super budget lift on the Jeep I feel more comfortable doing the install myself.
Doug
Thanks for the recommendation.
Doug
Doug
