How do you remove these?
Old 01-20-2012, 04:36 AM
Default How do you remove these?
Im adding a hood decal and need to remove these...then re-install...
The underside looks like a rubber cone shaped thing but can't figure out how they remove without damaging something.
Old 01-20-2012, 04:50 AM
FoxRacingJMC's Avatar
You gotta compress the inner cone so part of the edge sticks through the hole and then just yank it out. You should be fine and not tear anything, they are pretty solid rubber bumpers. Sorry, I know its easier said than done, can't explain it any other way. Like I said, Just stick a screwdriver or something with a little of a point and wedge part of it through and then just pull....
Old 01-20-2012, 04:53 AM
GreenJK07's Avatar
Yupp! Try needle nose pliers and they will come right out!
Old 01-20-2012, 05:51 AM
Thanks guys, let me try to just push it out!
Old 01-20-2012, 05:53 AM
EClass's Avatar
When I dry hood towel snaggs and pulls them off. PITA. Easy to put back on. Push hard and twist.
Edit: I guess just pull and twist to remove!
Old 01-20-2012, 06:39 AM
Got em off...the key is to twist them due to the double sided tape underneath ...used goo gone to get rid of the sticky shit on the hood and put the 2 knobs in the microwave for 15 seconds to get the glue off the knobs...
Old 01-20-2012, 06:41 AM
What hood decal are you putting on?
Old 01-20-2012, 07:02 AM
Its similar to the Artic jeep decal....flat black rectangle type design...I will post a pic when it goes on.
Old 01-20-2012, 07:15 AM
Guessing you are putting it on as we speak with all these pics of you removing the bumpers on the hood and whatnot? Curious to see the outcome, I'll be on the lookout.
Old 01-20-2012, 07:20 AM
EL LEON JK 07's Avatar
Just twist and pull and the same time. works every time!! do the same to put back on twist and push
Quick Reply: How do you remove these?
