How do my alignment specs look?
I had to go to Sears for a new battery today and they did a free alignment check. I just had it aligned about a week ago after getting front and rear 60s and 37s put on. It drives good just curious how these numbers look. I will be installing adjustable control arms this week(stock right now) of that will help. Thanks!!
Looks like they just did a static alignment check beings there is no caster readings. Which means they only used alignment heads on just the front wheels. Also there are no numbers showing what you actual readings were.
Yeah, all that's on that sheet is the stock specs for toe and camber, no castor, and no readouts of what you are at right now at all.
Edit, looks like they gave some kind of camber readout on it, no toe though or max at the toe tolerence?
Or just some kind of readout that your at the max spec on toe and camber on one side and the other, doesn't look like normal readout to me.
Hell , bring it somewhere else, that readout is funky.
