How did I bend my sway bar link?
Old 09-16-2015 | 11:23 AM
scubatech's Avatar
Originally Posted by Vladimer
For all I know it could of, but I went through all of the bolts and nuts on Thursday to make sure everything was tight and did not notice it then. It has quite a bend to it so I would of think I would of noticed but its always a possibility. How did you manage to bend it hitting a boulder though? It would have to be quite the specific shape to get inbetween everything around the passenger side to hit the sway bar link no?
I didn't take the tire off but looking around it and feeling it there was nothing new.
Yep, it has the high steer kit. The swaybar extension is suppose to be used if you are using the synergy sway bar disco kit which I am not. I didn't think about the links against the drag link though... Could they bend back against the drag link?
I set mine so the swaybar links are slightly above level as they face to the rear. I've seen the axle drop with too short of a ling and wrap it into a pretzel. Yours isn't bent that badly.
Rob 12B1P's Avatar
Bet for the lift they took the rear links and put them on the front. Looks from the picture that the OP needs links 1" or 2" longer than what are on there.
Old 09-16-2015 | 11:27 AM
Invest2m4's Avatar
Ah, I see you found the weak link in your setup.
