how come i only have this problem?
i have lifted jeep (4 inch) with 35's and when i corner at a normal speed the front brakes want to lock up and slow me down when i am already going slow. do i nee to turn off the esp? if i press the button it still does it. maybe i need to shut it off another way. it is a 07 if any can help please reply
I found the instructions in the manual. When they say turn the ignition to the on position, do they mean start the car? Asking because it is a bitch to turn the wheel without power steering.
I heard the manual process doesn't completely turn the esp off. I tried the hole wheel turning deal but i couldn't get it to work. I tried a couple of different ways i found on different threads but with no success.
alittle trick i did to turn the esp off was after i put my SS i already had my jk in the air so i did the owners manual code and it was alot easier to turn the wheel and do the code when the jeep was in the air. hope it helps
the esp activating is the best sign that something is wrong in your geometry. correct it and then disable the ESP. My ESP is disabled right now (helpful hint which is easier than putting it in the air to do it, just start the jeep and do it while its running) but I plan to enable it when my lift goes on so I can make sure that I've got it right. I'll disable it after because I like beating the piss out my jeep and I don't want someone else applying brakes or cutting power.
