How big of tires?
Check this link.
https://www.jk-forum.com/forums/show...ery-Newbie-Has
U can safely run 33s. U can also run 35s but expect to rub. U will even rub with 34s but if u trim fenders or run flat fenders, 35s no problem. Still may have to trim pinch seam.
2" BB and 1.5" spacers? what does that mean exactly? 1.5" spacers on top of your BB spacers? 1.5" wheel spacers? a BB is a spacer lift, so if you have 3.5" of spacer lift, you can run 35s, maybe even 37s with flat fenders and extended bump stops, although i bet it rides like hell. if you mean a 2"BB and 1.5" wheel spacers, 33s or 35s with flat fenders and extended bump stops.
