how big a tire before the 3.8 V6 wont cut it?
You do have to remember with tires and weight, that rotational weight has a bigger effect on performance than static weight. If you sat a 100 lb weight in the Jeep, it would not have that much of an effect on the acceleration. But if you strapped the 100 lbs on the rims or tires, the weight would have a mulitplied effect, because the engine would have to work harder to turn the wheels. There are dozens of other factors involved in the tire size equation, friction, drag, tire pressure, etc... I agree with the other posters that other parts will have problems before the 3.8L does with huge tires.
just got to regear it to 5.13 and then you will be able to run what ever you want. Also depends on your lift height (if you have one even), make sure the JK can clear the tires without rubbing. It the not the engine that make stop people from going to bigger tires, it the gears. Hope this helps!!
Originally Posted by iphonedylan
This is dumb. Not trying to flame you but it's silly. The 2 door can tow 2000lbs and 4 door 3500lbs... Why do you think? Because the 4 door has a different 3.8L? The towing has to do with wheel base. It's also while you're only supposed to have 100lbs of tongue weight. Now 3500lbs might be nearing what Jeep believes the engine is capable of towing safely but if you throw 3500lbs on the 2 door and jump on the brakes at 60 mph you've got a pretty good chance of doing a wheelie and that would be youtube worthy... I believe there is a guy on here with the four door and a special hitch towing a 5500lbs trailer. I'm not saying it'd be fun but it works. Gears are your friend.
Originally Posted by Lancejk
As I stated and you regurgitated gears are your friend. Along with the fact that I have never seen or heard of 2500lbs of tire for street use. Good job hero you flamed a fellow jeeper for helping. Special little fellow aren't you!?
